mightyviking
- May 21, 2013
- 4
Hey there,
I have a 98 Johnson 35HP 3 cyl, Model - J35QLECA outboard that will not idle when cold without choke. It will eventually run perfectly after MULTIPLE restarts and manually revving the motor at the carbs.
So far, I have replaced the tstat, plugs, wires, coils, adjusted the slow speed jet (someone before me had set them to 5 turns out!), changed primer bulb on tank and finally last weekend, taken apart and cleaned all 3 carbs. I did notice that if I release the choke and it starts to die, my brother-in-law turned the red lever on the primer solenoid and it kept running by toggling it on and off which keeps pointing back to fuel starvation but I am at my wits end troubleshooting this problem.
Any ideas?
Any ideas?
