kobi-1-kenobi
- May 20, 2013
- 3
I have a 1964 Johnson Seahorse, model MQ-10R. This motor leaks lower-unit lube from the prop shaft area. I've read through my Seloc manual to remove the lower unit. Having removed the four bolts that hold the unit on, it drops down about 1/2 inch, not far enough to get a socket in there to loosen the lower bolt on the shift rod coupler. The manual says it should drop about an inch. It also says there may be a pin in the drive shaft that would need to be lined up with something in the housing. Not sure if this motor has that. Any advise would be greatly appriciated.
