Re: Female here trying to restore boat for hubby
I totally agree with 'Wood', you should definitely check the guts of the boat to be sure of what you actually have on your hands before getting into anything cosmetic...
If the underlying wooden substructure is rotten, you will need to take care of that first...
A good pressure cleaning is not a bad idea... I wouldn't even worry too much about it being gentle, as a matter of fact, I would rather find out from a good pressure cleaning if the surface of the boat is solid or in need of refinishing...I don't mean that you should blast it to within an inch of its life, as some pressure cleaners can actually cut into concrete...Just give it a good once over to look for lifting/peeling paint, if it is painted or to get a good look at the condition of the gel coat...
