skeeterbug
- May 20, 2013
- 1
Hey guys, been lurking for a while and decided I may as well join the fray. A few days ago I purchased an old '85 Skeeter Starfire 115 with an '85 120 Johnson on it. The boat had sat for about a year, but the fuel still smells fine and the carbs aren't gummed up at all (at least the two that I opened up. The problem I'm having is a popping in the exhaust and a misfire at low rpm's. With the airbox off, the are occasional little "spits" of fuel coming from the larger of the two jets on the front of several of the carbs and the airbox had probably a couple of tablespoons of fuel in it when I pulled it off. It starts fine, and runs great at high speed (showed 53 mph on GPS), but as soon as I throttle it back, it goes to missing again. The top right plug is wetter than the rest, but they're all wet after idling. It has new plugs in it and compression is 135-140 on all cylinders. I'm thinking maybe a bad reed valve, but I'm not a two-stroke guy. Any suggestions?
