Hello,
I suppose this has been asked here a million times before but here goes. A bit of background. last year I bought two 1967 Mercury 650's. A short shaft, and a long shaft. The long shaft was an "extra" motor the PO had laying around and wanted gone from his yard. I do not know what condition it is in, nor if it even runs or not. I stupidly mounted the short shaft to my boat thinking all would be golden, but upon test running it this weekend, I discovered that I had made a major miscalculation. As my boat goes up on plane, the prop ends up about 1/2 way out o the water, and thus I lose power, traction, whatever you call it, and the engine revs. The shaft on my motor just isn't long enough! So I was wondering how huge of a job it is to swap the short shaft leg parts with the ones from the "junk" motor? Possible??
I cannot modify my boat's transom to put the motor any lower. It is a 1989 Bayliner Capri 1500. It is in pretty good shape yet, I would like to get a couple of good years out of her yet. Thoughts?
Don
Don
