Re: 1990 90 hp vro
Those rubber water diverters are in the block, between the cyl liners and the block. When that engine runs WOT, the nylon pressure relief valves inside the thermostat housing must open for extra cooling water flow. You may want to open the housing up, check the diverters and even install 2 new thermostats for good measure. If the nylon diverters ever get overheated, they can deform and not work properly.
