bluecollerboater
- Jan 2, 2007
- 123
I have a 5.7 gipmda that is hard to start. What I have done so far is to take the s terminal off the starter solenoid and turn the key to start. I heard the fuel pump run for 3 seconds or so to prime the fuel. Then I turned it more to crank and did not hear anything. So I reconnected the yellow wire to the starter solenoid and cranked the engine. It took about 10 seconds to start and I noticed when it did start was exactly when the oil pressure built up. Then I took both relays near the low pressure fuel pump and cleaned the connections. I put them back in and for the first time since I have owned the boat(2 months) it started on the first turn of the key. I could only get it to do this twice. Now it still takes 10 seconds of cranking to get the boat running. Does this sound like a relay going or gone bad or something different? Thanks in advance for any help.
