gulfraider06
- Oct 17, 2012
- 1
Can anyone suggest what might be wrong? There is a leak somewhere and apparently the water is traveling through the shift cable and is dripping down from the threaded end. I replaced the lower shift cable and seals and bellows. I ran out of time and had a mechanic finish up and install the drive. Is it possible I or they installed something wrong? It is a mercruiser alpha 1 1986 with a mercruiser 190 3.7 liter. The boat actually has twins the other one I replaced works fine. Thanks.
