TWIN 2007 E-TEC 75HPs Can the Injectors and EMM be swapped without reprogramming once the oil setup is the same.
One of the engines is blowing the fuse when key turned to the start position the gauge only goes through its check sequence when the emm is disconnected and the fuse stops blowing.
I think the EMM is in trouble and is there anywhere these can be repaired.
Does anyone know the component sequence of operation for starting.
Thank you
Thank you
