Rick on another thread you mentioned the following?
?.A WOT RPM that's too low can damage the engine.?
I have a 4.3 and very seldom run at WOT. I grit my teeth when I look at the RPMs above 4000. I would never run a car engine at this speed except for passing/
Are these standard blocks from GM or are they designed to run at much higher RPMs than the car engines?
Everyone's thoughts are welcome.
Thanks for another Ricky
