Engine ran fine when stored 3 years ago, has compression, rolls over fine, no spark, has no power from ecu Connector D-1 to MAP, Crank Sensors, Cam sensor or anything else on that leg from the ecu, 2 engine fuses are good, have battery Voltage on B-5, What is the voltage supposed to be on D-1? Cars use a 5v or 8v. I'll supply that and see if it fixes it before I by a new ECU, From the ECU connectors All sensors ohm out per the manual, this engine has less than 50 hours on it, Any suggestions, The ECU is not cheap. Thanks,
