twocyclemania
- Aug 10, 2010
- 505
Replaced the broken spring in the recoil of a recently acquired early 50's 3 Evinrude. Seems to work fine until I mount it on the engine. It 'grabbed' and worked the first few pulls. Does not want to engage anymore. Every time I remove the starter now I find the bolt that holds the spindle is loose (yes the washer is there). Also, the small nipple on the end of the spindle that engages with a corresponding hole is there and I do have it lined up. Yes, the three engagement arms are in place along with their springs. Did I miss something or a part?
