Re: Johnson needs help!
You have a fuel supply problem. Sounds like dirt in the tank blocking the pick up tube. If you have had fuel in the tank for that long without Stabil you are in deep doo doo. Todays fuel goes bad after about 30 days. To keep it fresh you must add Stabil when you fill up. Once it is bad get it out. Chances are that the bad fuel has caused a build up of shelac, brown crap, on the sides of the tank. This washes back into the fuel and causes blockages. Been there done that. You will probably need to remove the pick up tube to clear the tube and check valve. The bad fuel could have caused blockages in the carbs so if you want to avoid a blown motor strip the carbs, clean and rebuild with new kits. Remember if the carbs don't work correctly the lubrication will not be there.
