I have a 1985 Merc 75hp 4 cyc 2 stroke. The boat has sat for several years unused. I have redone the fuel lines, cleaned carbs and replaced floats, needle valves, and made adjustments. When running the motor sounds great and runs fine but when killing the motor fuels drips out the throttle shaft valve and the top carb pooling in the bottom of the motor.
