tabirdsall
- May 17, 2013
- 5
the problem is at any speed seems like its slipping out of gear for split second then slams back in ,motor runs great has new cdi power pack help im on here and not fishing
Sounds like a lower unit problem. Possibly(and most likely) clutch dog is worn. Do you have any problems shifting it into and out of gear?(shift linkage adjustment?)
Have you had the lower unit off prior to this problem? best of luck. Rick.
