1980 85 hp 2 stroke johnson
I just bought this motor today and replaced the impeller/housing/gaskets/o rings and the lower unit gear oil like I do on every motor I buy.
I started it up and water only comes out of the exhaust holes, a lot of water shoots out about 10" of heavy flow...I have never had this problem before so I took off the thermostat housing and blew air through each head and I could feel the air coming out through the pee hole on the head...I started it again without the thermostate housing on and only a tiny tiny bit of water was spitting out of the left side where the thermostat should be
What would cause this?
The motor starts right up idles fine and sounds great but that's only for a few seconds because I don't want to get it hot
Sorry won't let me add photos
