I just recently purchased a 91 Chriscraft Concept 17 footer with a 2.3L cobra.
How can I check to see if I have the updated shift cable?
Thanks in advance for any help.
What you will have to do is remove the drive check your bellows, ujoint and readjust the cable using a special tool. While adjusting you will be able to check if it is binding. At this point it no diference if it was updated or not, your boat is over 20 years old. Adjustment is very easy to do if you have a proper tool.
