AL350SEARAY
- Jul 2, 2011
- 33
Thank you for taking the time to view my post. When dewinterizing my Searay it started right up after pumping the throttle a few times. Ran it on the hose for a little while and turned it off and restarted it several times. First time out at the lake it started perfectly. I put it in the water and pulled up to the dock. I went to grab my cooler and when i came back it was off. It would not restart and does not have spark at ignition coil main lead. It has a conversion to a electronic ignition system with an ignitor. Battery shows 13.2v and i am getting 12.4V at both the + and - sides of coil.
I disconnected all wires to coil except the 12v+ power source and the wires coming from the ignitor. I have installed a new ignitor kit with a new rotor and cap. When cranking the voltage drops to 10.5V at the igniton coil. I tested resistance between + and - posts on ignition coil and it is 1.4 ohms. Also tried it with another ignition coil which shows 2.4 ohms. It ran perfectly at first, which i knew was to good to be true. I don't understand what could have caused it to die. I have read several posts in the last few days and have tried the things they recommended. If anyone has any suggestions on my next move i would appreciate the help. Thank you.
