planeracer
- Aug 5, 2011
- 12
Hello,
Today I decided to change an oil on my volvo 275 outdrive and oil was milky, then after bellows inspection found lot of cracks on it, last year oil in outdrive was ok, but im not sure if bellows leaked or not. As soon I removed bellows from upper gear drive milky water came out, boat was sitting on trailer from last october, and I'm not sure why water didn't leak out. Now, looks like I need to remove flywheel sealing ring to inspect to see if any water went in. Is that hard to do? Do I need to call for mechanic to do it? Probably I need replace that sealing ring after it removed or I can use old sealing?
And looks like part number for that sealing ring will be #958860. Probably I need to replace sealing ring on upper gearbox to. Or need to get whole gasket kit?
Thank you for your attention.
