new 2 boating
- May 16, 2013
- 2
I have a 2005 merc 125hp 2 stroke, It idles fine, starts fine, and goes into gear fine. My problem is when I hit 2600 rpm on throttle up, UNDER LOAD ONLY it starts to skip,grind,jump, in what sounds like the top end of the motor?. The prop still spins when its doing this, I've done the plugs, wires, put new leg oil, and the compression is 150 psi in all 4 cylinders. im pretty sure I didn't hit anything and there's nothing caught in the prop.
