I have a 1983 boat with a 488 engine. I recently talked to someone with the same boat and motor (century 5 meter) they said their boat did 53 and had a ticket to prove it. My boat will only do 47. I have changed plugs, done a compression test everythings fine. My boat runs good and hits the top of the rpm range even full of people. It runs really good no antifreeze cam seal leaks all plugs come out the same greyish light brown. I dont think the temp has ever even hit 160 f. Just can't think of anything else that would cause my boat to be that much slower than the same model. Would a stainless prop or ingitor halls effect ignition make that much of a difference? I have even weighed my boat to see if it was heavier than advertised weight which it is not. It seems like something stupid to worry about but makes me think there is something wrong. I don't know the prop setup used to hit 53
