fishinrado
- Nov 8, 2006
- 137
well I thought I had solved the drive oil leak. I had a small amount of gear lube coming out the port water intake holes.
new to the boat late last fall so I pulled off the lower and replaced the water pump and seals, the 3 drive shaft seals below the pump, the shift shaft seal and rubbers and the qaud seal. took the boat out for several hours on Monday, no oil anywhere . went out today and happen to walk by the boat and found a good amount of oil on the ground and this time it's coming from the small hole in pic also on the port side. did i miss something or is it now the seals that the drive shaft slides into in the upper unit?. I did notice oil around that hole in the upper while inspecting it with a flashlight prior to assembly. no water in the oil prior or now in the gearcase.
Thanks for any input.....
