Re: Fuel and oil OMC 3.0 >
What a coincidence! My boat is a Forester as well! I think that MFG lasted only two - three years. However, mine is 1990 w/4.3 liter motor. I will be searching for manual/s too, but for a tip, locate your model and serial numbers for the engine and drive. The drive was pretty easy (little aluminum tag) but I still haven't found my engine model. As stated before, it's a 1990 boat I bought new in the fall of '89. But I am fairly confident it is '89 motor because it has points. Right about '90 is when they switched to CDI ignitions and mine was a left over I guess. I selected this Forester at the time because all of the specs I researched, it had the most HP, least weight for the least $. 205HP - 2100 lbs, ~$12500. Anyway, once you know what motor / year is, should be able to pic up off Ebay. Or maybe one of the pros here will chime in with a source.
