DP-C/290A Drive, regarding the pivot pin that connects the steering helmet to the upper gear housing bearing box.
First off, is my pin normal? Using a pick and measuring the depth of the holes for the allen bolts, I get roughly 1-1/8" (eyeballing) until I reach the threads of the upper gear housing's bearing box. This includes the depth of the recess for the allen bolt heads. However, when I measure the depth of the smaller tapped holes which are used to jack the pin out, they both bottom out at roughly 7/8". The bottom feels solid, not like debris buildup.
At this point, I'm on the verge of breaking the 2 extraction bolts if I tighten any further and the pin is not budging. When I wiggle the leg a little, I can see some play between the pivot pin and the bushing in the helmet, so I don't think it's binding there. I would think, but am not sure, that the pin receiving hole on the bearing box would have a flat bottom other than the threaded holes for the allen bolts, meaning the depth of the smaller holes ought to be the same as the larger with regard to the pin only.
Also, the bolt's I'm having to use are 1/4-20s (not 6mm) and the smaller holes are not threaded until about 1/2" down.
Any insight would be appreciated.
