Re: 1983 Johnson 150 one dry plug
Well i will try the spray bottle idea this afternoon if the rain lets me. To answer your question on me using the removal tool to remove the jets when i rebuilt the carbs... well lets just say i didnt remove the jets... which could be my problem.. I believe the high speed jets are the ones that you see when you remove the two flat head screws on either side of the bowl, is that correct? Maybe i should start with my version of rebuilding the carbs. I removed the carbs, opened them up , removed the float and needle valve, shot chemtool carb cleaner through all the little holes and put it back together. ( i didnt remove the little silver disc). well with that being said i may not have done all the steps i needed to.
There is no fuel coming out of the middle carb as far as out of the front of the throat. where can you get the jet removal tool at?
