mburmeister
- May 6, 2013
- 6
I got a '67 Mercury 39 (3.9 HP) with a jon boat I purchased last fall. The boat and trailer were worth what I gave for it so the motor was a 'freebee', and the guy who had it before me never used it.
I put it in a trash can of water and that baby started right up, however I noticed there was no water coming out anywhere and just a bunch of smoke - so I shut it off immediately.
I pulled the lower end and found the impeller to be in pieces (I found and removed all I'm fairly certain). I ordered a new impeller, installed it, put it back together and still no water.
The lower unit was pulled again and the copper water pipe was checked for obstructions - none found. Ran fine wire into the tattle tale hole and when it pulled out it was covered in dark grease like material.
We then pulled the powerhead and the cover over the W shaped maze which drains to the tattle tale. This was full of all kinds of that dark grease. We cleaned it out and all the canals in the powerhead and bolted it back on. Fired it up and it would surely spray water right? Wrong.
There was water spraying out of the small hole next to the bolt underneath on the side, but what feels like only a fine mist and warm air coming out of the back tattle tale. We even pulled the fresh water flush plug and water was pouring out of it - so the pump is working fine.
I'm not sure what to even try anymore. When looking at it with the powerhead off, we couldn't even figure out how the water would get into that area where the tattle tale is located? There is no hose which leads to it or area that would drain into it? How does that work?
Please help! My grandpa and I have spent hours on this and he is giving up. Thanks!
