Re: Alpha 1 Gen 2- shift bushing and vent line help?
It was the Speedo connector, got that ordered.
Been doing research on the shift shaft bushing and still having trouble with that. The part that I'm referring to is a little black bushing, about 1/2" diameter, 1/4" tall (if sitting on a flat surface). The bushing came off and was sitting on the ground when I pulled the lower, so I'm not certain but assuming it's the shift shaft since it fit. Felt like rubber or maybe poly/plastic. A couple questions:
I've read quite a bit and came across part number 26-89236 1, but I'm not sure if that's correct. My shift shaft seal looked good, just this bushing, whatever it went to, needs replacing.
1. Anyone have the part number for a '95 alpha 1 gen 2
2. Does it just slide on the shift shaft and sit above the shift shaft seal?
3. Can it be replaced without pulling the lower
4. Can I run the boat without it? (In-laws coming up this weekend and want to boat)
Thanks for the help!!
