RustynMtnHome
- Oct 2, 2012
- 23
I recently purchased a used Minn Kota 80PD, before purchasing I ensure it ran, and did all the good stuff and it did. Now on the first trip out, on two different occassions when I switched it off and then went to proceed again it would not come on ..... so the first time I pulled it up out of the water and laid on the mount and it started working, the next time I just smacked the control box on the motor while it was still in the water and it started working. So I am presuming there is a loose wire in the control box somewhere .....
Here is the question, is it easy to take this apart, and what wire might be the first one that I look at to ensure it is tight
Thanks in Advance
Thanks in Advance
