David DeLong
- May 13, 2013
- 5
I just bought a 2002 seaswirl striper with an evinrude 175 ficht motor on it. Motor has under a 100 hrs on it. Compression is good across the board. Boat had not been run in a couple yrs so I drained out about 50 gals of gas from the tank. I had new fuel and also installed a fuel filter/water separator. The motor has new plugs. It runs great at an idle to about 2500 rpm. after that it seems to be starving for fuel and it loses rpm. What should I look at before bringing it to a Marine Mechanic? I'm gonna check fuel pressure after this post at an idle. Thanks for any help you can add.
