2005 Yamaha 4 Stork Ignition switch
mikelinda
Motor will not shut down with key or kill switch! I removed the switch and cleaned the connection no help! should I replace the switches!
99yam40
Re: 2005 Yamaha 4 Stork Ignition switch
test them to see if they work and then check to see what wire is broken or disconnected.
They ground the ignition system to keep voltage from getting to coils and plugs
What is a
[h=2]Yamaha 4 Stork[/h]
Don S
Ya must have missed the 4 stork series completely.
attachment.php
99yam40
think everyone I know would avoid them 4 Strokes
Cost way too much in the long haul
