dzurinko
- Apr 12, 2013
- 65
I've got a question on Self Etching Primer. I'm refurbishing a 16' Aluminum Mirrorcraft that will be on a trailer or in freshwater only. My original plan was to use Zinc Chromate on the couple dozen minor scratches before putting on regular primer. But when I took the boat off the trailer and flipped it over, there are hundreds of small scratches all over the bottom. Even with all the scratches, there is still good paint over 90%-95% of the hull but by the time I gave each one a spray of Zinc Chromate, the bottom would look camouflaged. Where its not scratched, the original paint is in great shape. No peeling or loose paint anywhere and its actually quite shiny where its not scratched. Now I'm rethinking the Zinc Chromate spray on what I thought would be a couple dozen scratches. Can I sand the entire hull just to only get the shine off, then paint the entire bottom with a roller using self etching primer in a quart can? Is it acceptable to even put SE over good sound sanded paint while hitting the scratches? Then a normal primer over the SE? I'm near a Lowes, Home Depot, and a Tractor Supply. Any recommendations from those stores for a quart of SE if I can paint the entire boat with it? Otherwise, it'll be a lot of small spray spots everywhere.
