Morning guys, been a while. Anyway I am dealing with some key switch issues this weekend. The boat has been sitting for quite a while. When I went to start it I had no power to the key switch. I went through the ignition system and battery and cleaned all the wire connections. This time I turned the switch on and got power to the gauges but nothing when I turned the key to start or pushed in the primer. I pulled the key switch and did a continuity test and everything checked out ok, I put the switch back in and the gauges once again worked but nothing happend again when I turned the switch to start.
After a half hour of blindly fooling around I went back to the motor and jumped a wire to the yellow/red wire of the starter solenoid. The starter worked. I went back to the helm and turned the key and the starter engaged. I thought I had won but was soon disapointed.
I cleaned up my mess and went back to the helm to start it one more time and this time when I turned the key on I once again got no power to the switch (no gauges or anything). I have retraced my steps from yesterday and still have nothing. At this point I am open to any suggestions.
Thanks in advance,
GatorMike
Thanks in advance,
GatorMike
