Texasmark
- Dec 20, 2005
- 14,558
Mercury V6 engine cooling hose routing has been on the Merc forum a few times recently and I have a puzzling question that has intrigued me for many years and seems like time to ask about it.
My son had a '96 as I recall Merc 150, V6 2 liter. It had thermostats at the top of each bank of cylinders and a high rpm popoff coming off the top of the block via a hose and dumping into the mid section.
The tell tale was plumbed off the output of both stats in parallel off to a single hose that was the tell tale teed off the dump hose for the stats. The stats and the popoff did not join each other with flow from their outputs like I think my 90 does....can't find proof one way or the other on it.
As a result of this plumbing you don't know if you have cooling to your engine until the water in the block gets up to around 150F. Then one/both stat(s) open and you get some miserable spurting out your tell tale until the stat cools off and shuts if off, which at idle, especially in cold water isn't very long....measured in seconds.
So what's the point of the tell tale? To me the most important time to know that your water pump is working is when you are launching your boat and first crank up your engine. I want to know before I back off the trailer that I have cooling water. Real stupid design as far as I'm concerned.
So, on my son's engine, I moved the tell tale from the stat output to the hose coming from the top of the block sampling cooling water in the block's water jacket that goes to the pop off valve. In this configuration, I have a nice solid stream of water out the tell tale as soon as the block fills which is a matter of 10's of seconds. Knowing that I/he can launch and go and enjoy a days boating.
So in short, what is your opinion, or do you know as to why Merc decided to do the tell plumbing as they do?
Surely others with those engines are interested in the answer.
Thanks,
Mark
Thanks,
Mark
