Re: Do I need a fuel/watter seperator?
I change the seps on my boats about once a month and always keep the tank topped off when the boats going to sit for a while.. <br /><br />Recently I had big problems with the insides of my seperator rusting in a very short period of time... I don't mean a little rust either... The metal top of the spin on sep/filter looked like a science experiment gone wrong... Cut the sep/filter apart and found rust on both sides of the filter element.. Fuel injectors, regulator, the fuel rails, lines, all full of rust particles... (plastic fuel tank)<br /><br />I removed the entire filter assembly, cleaned it very well, put it back in the boat, and installed a new seperator/filter... Did all the other repairs to the fuel system as well... Ran the boat on the hose, everything now ok except the $wallet$..<br /><br /> Three days after the repairs, just for kicks, i pulled the sep/filter off to see if i had any water in the fuel... Well, as i suspected, there was some water in the fuel, and the brand new three day old sep/filter was rusting badly...<br /><br />That seperator/filter deal is gone now, replaced by a cheap plastic filter (temporary untill i find something better)...<br /><br />My opinion... A plain old particle type filter is best... A little water in the fuel will burn off.. And with the possibility of rust being able to form in the seperator, it's just not worth the risk to have one...
