Re: 73 1150 bad rectifier cause no spark condition?
Brian, usually you can clean up the cap and contacts. As long as it's not cracked/physically damaged/arc-marked, it should be OK. A good blast of carb cleaner will do a decent job of cleaning out old, gunky deposits. Check the carbon contact for free movement & damage, it's not a real $$$ part to replace. If you pull and twist at the same time, it'll usually come right out. Check the contact spring for damage as well.
The rotor is cast onto the shaft and is non-replaceable. Maybe post a pic of the crack, the only concern I would have is if the rotor's structural integrity was compromised, as any parts which "grenade" inside the distributor are gonna take out the new trigger.
A new rotor was over $460 when last available from Merc, but there aftermarket replacements available; some new and used rotors are listed on eBay but still over $200 for any new one. So, unless there's some "terminal" problem with the rotor, you should be able to clean it up and re-use.
There are 2 small ball bearings in the distributor, the lower bearing is commonly available, for some reason the top is NLA from Merc, and expensive. But if you have a bearing house nearby, all they need are the numbers off the bearing and they're easily matched-up. Or take the numbers and order online. Last time I needed some I took the bearing #'s down to the local NAPA store and they were able to order them.
Be sure you don't buy bearings made in China, they're of dubious quality. Name-brands such as BCA, NTN, Fafnir, SFK, Federal-Mogul, Timken, etc are all good ones. The upper bearing pries out of the dist, if you're very careful you can pry it out without damaging it. Use 2 small "tweaker" screwdrivers in the small holes and pry on the outer races, not the metal shields.
The lower bearing is held in by a snap ring which should always be replaced, as the ring will rust then break with age. Another thing to grenade the trigger! My old 1350 did it at a very inconvenient time, fortunately back in the 80's a used dist assy at the Outboard Boneyard was only $50. Not gonna see those prices again! Once the snap ring is removed, the bearing drives out from above. Always replace unless it feels perfect.
Just be very careful when taking the dist. apart, as things can be damaged if forced. With the dist. removed, you pry down the lock tabs holding the top and it unscrews. Then comes the aformentioned top bearing. After that, you'll be able to see the nut that holds the rotor into the housing.
The best way to undo the rotor securing nut is by using a small imact tool with 3/4" deep socket. Hold the rotor in a gloved hand (to avoid damage to hand and rotor!) and give the impact short bursts (normal, Right-Hand threads). The nut should break loose easily.
Here's a couple of reference auctions on eBay, so you'll get an idea of the parts involved:
CDI Electronics Mercury 4 6 Cylinder Distributor Rotor Shaft 994 4371 | eBay
Trigger Kit for Mercury 4 6 Cylinder CDI 134 3736 Replaces 393 3736 332 4177 | eBay
Here's a couple of parts diagrams for the distributor:
Mercury Marine 115 HP (6 CYL.) DISTRIBUTOR HOUSING AND ROTOR Parts
Mercury Marine 115 HP (6 CYL.) DISTRIBUTOR ADAPTOR AND VERTICAL LINKAGE Parts
Last but not least, the CDI-Electronics installation guide for the replacement trigger, has good instructions for disassembly of the distributor as well.
http://www.cdielectronics.com/wp-content/uploads/2013/01/134-3736.pdf
HTH...........ed
