Re: 1968 evinrude 18 hp rpm questions
It will idle smoothly in a barrel at around 750-800, but much lower than that, and it gets a little rough. It shifts pretty smooth at that rpm, so I figured that was probably around where it should be, but my neighbor thought it should be quite a bit lower than that, so I figured I'd ask on here and see. I haven't had it out yet since all the work I've done on it, but I wanted to know what I should expect when I do get it out and to make sure the prop is right on it.
I have it on a 16 foot mod v lonestar. I was getting about 16 mph out of it the first time out (no tac at the time, just my gps) but the acceleration was horrible, and it just wasn't running very well. The trim was also off a little, but I was afraid to take that pin out on the water. Since then I've rebuilt the fuel pump, ignition, water pump, carb, and resealed the low end. Based on how bad it was running that day, and the trim being off to, I was thinking I'd probably get close to 20 mph out of it once it was running right and trimmed right. Sounds like that might not be too far off because your 14 looks to be built a little wider and deeper than my 16 so I'd say the weight isn't a whole lot different.
