Good morning,
I just bought a 1997 Chaparral with the 4.3 Mercruiser. The engine and outdrive run great (just tested outside with the ear muffs). A couple of days ago, I changed the gear lube to the QuickSilver HP and filled the reservoir. I just noticed that the reservoir is empty and I see gear lube leaking from the portside small hole (the small hole on top of the water intake...right under the rear port side bolt that holds the lower unit).
Here is my question:
Should I just buy the impeller kit and just replace the impeller and the seals?
Thanks!
Thanks!
