Re: Trim limit swich location?
Limit switch? As I recall the trim motor will drive as long as you have power to a blue/white or green/white wire. What happens is there is a pressure limit valve in the hydraulics that opens and bleeds off the pressure when you are at a limit and keep driving the motor.
"If you bypass the solenoid....." What solenoid? The first things most folks do on here in a situation like that is to swap relays and see if the problem follows the relay. Then replace accordingly. Otherwise the problem could be the control switch no longer powers the up relay, or you have a broken wire from the control to the up relay. Power to the blue/wh. stripe wire is up, green/wh. stripe is down.
Mark
