Johnson 40HP J40RLSRS 2004 - Gearcase seal kit replacement, removal of drive shafts
bollies
Hi all,
Thank you in advance for any advise.
We discovered the lower unit was leaking oil between the prop shaft and propeller.
It was due to get a new impeller and thought we would replace the gear case seal kit at the same time.
We pulled the lower unit off and removed the water pump and all screws/bolts, but we are now stuck with the two shafts(upper(main) and lower(propeller shaft) still in place.
I only have a parts manual and from what I can see is nothing is holding it in place.
I read online that there could be some sort of clip holding the upper shaft onto the lower and a OMC tool is required but can't find anything in detail regarding this.
If I was to remove the bearing housing, how do I as it is pretty tight, would I see this clip and would I be able to remove it ?
Or what is the best way to remove these shafts?
Many thanks in advance
Regards
