just got a 1995 25hp johnson. won't start unless you spray starting fluid into carb, once you get it running and warm it up, i can shut it off and start it up right away. but if you leave it sit for a few minutes and cool down, it won't start again. also if you try to prime it, it seems to flood and soak the spark plugs. I checked the compression and it is an even 125psi and spark is good. what is the factory carb rich/lean setting?
can these style primer solenoids cause starting issues?
thanks, Don
thanks, Don
