I have a 1977 johnson 140 vro ....heres my issue it has started the past 4 weeks with the muffs on and just today it cranks but wont start...things ive checked is fuel,spark,new plugs checked and found one wire cracked so i fixed it ..Motor will just crank pop once in awhile bur nothing else....Question i have is the red switch on left side of motor should face up? another question is i have never seen so much fuel and oil pour out of the bottom by propeller could this be from trying to start non-stop?...also pulled off fuel lines from motor and cranked fuel is going through..also the new plugs have no show of wear after trying to start for an hour today?,,
Thanks you for any help in this...
