I have a 1983 mercruiser 351w that overheats at wide open throttle. Every possible system related to the cooling water has been gone through. Next thing was a compression test, however, Im not sure on the results?
Here are the compression test results: Is there a head gasket issue between #4 and #6 cylinders??????
Wet compression test results:
1 130 2 128
3 140 4 117
5 130 6 100
7 145 8 140
Dry compression test results
1 121 2 122
3 138 4 110
5 120 6 95
7 130 8 130
1 130 2 128
3 140 4 117
5 130 6 100
7 145 8 140
1 121 2 122
3 138 4 110
5 120 6 95
7 130 8 130
