Rustymiller
- May 9, 2013
- 3
Greetings:
I have a 25 foot glastron with a Volvo Penta 280 outdrive. I am having issues with the electric tilt device. How can I grease the tilt shaft or what can I do to make it work better. It will lower the unit but will not raise it unless I lift it by hand first. Seems to run out of power. Been sitting for at least 4 years. I am thinking it needs some grease but cant find a zerk or any way to add any.
I also found a plastic plug down at the bottom area on the right side, what is this for?
Thank you all so much for your help.
