Should I use a sealer on the 6 studs when re-attaching the outdrive?
T Tsteverson Cadet Joined Aug 8, 2011 Messages 7 May 9, 2013 #1 Should I use a sealer on the 6 studs when re-attaching the outdrive?
vwbugman69 Petty Officer 2nd Class Joined Jul 11, 2011 Messages 116 May 9, 2013 #2 Re: sealing compound? I usually just put a small amount of spline grease on mine.
Don S Honorary Moderator Emeritus Joined Aug 31, 2004 Messages 62,321 May 9, 2013 #3 Re: sealing compound? Grease works great, and doesn't make near the mess sealer does. It's only there for corrosion protection, not sealing.
