nextboat1
- Mar 17, 2013
- 82
Hello, I took the boat out today and noticed that water was starting to accumulate in the bilge, enough to kick on the pump a couple times in about an hour span. I first suspected the bellows, which I changed a couple weeks ago. I pulled the drive and everything was dry as a bone. While on the water I crawled in the bilge to look around and could not see a source for the leak. All the hoses look good, block plugs look good, manifolds and risers look good ect. I do not have any thru Hull fittings (transducers ect.) The boat is a 21ft cuddy with a mercruiser 5.7 and an alpha Gen 2 drive. It also has thru Hull exhaust. The y pipe is still installed and capped inside the boat. Any help would be greatly appreciated.
