Re: Will this triple groove lower crankshaft pulley replace mine?
Ok, I received my new pulley. I paid $34 + $8 shipping = $42 for the new puley from whiteperformance out of Kingsport, TN.
I have not installed the new pulley yet, but here is my visual comparison between the new aluminum pulley and my old one.
1. Holes - the center hole and 3 mounting ho where it mounts to the harmonic balancer are the same.
2. Diameter/radius - The new pulley is about 3/16" smaller than the old pulley, that said, the grooves in he old pulley are about 1/8" deeper than the grooves in the new pulley, so there really isn't much difference in the circumference.
3. Width - this where you will see a difference. The old pulley is a little over 1/2" wider than the new pulley. On my engine, the first groove (the groove closest to the harmonic balancer) is my alternator belt. The width difference will not affect this belt (which is the important one in my opion). The middle groove is not used. The 3rd groove is used for the power steering belt. This groove will be a little over 1/2" closer to the engine than on the old pulley. I do not know if this is a deal breaker or not. For me, I do not care if the power steering pulley is perfect. I will look and see if there is any way to get the p/s pump to move closer to the block and align better.
Here are some photos of the two pulleys together.
