hello to all. Okay here is my problem. i aquired a control box and cables for my 77 70hp evinrude. I disconnected the old cables from the engine and proceeded to run the other cables when i noticed they were rather longer than the old cables. didnt think it would matter so i stuffed everything inside the side of the boat. i hooked up everything ( which i had to adjust the trunion nut) and now i cant get the motor to start. it will turn over and i have fuel in the cylinders and carbs. did i screw up with the installation of the cables. i also adjusted the fast idle screw.please help
