I recently purchased the above boat. A few weeks ago, I drained the overhead water tank for the shower into the shower pan. It backed up. I looked high and low (literally) for a valve that may switch from "dump" to drain like the sink has. No luck.
Under the boat, below the shower, there is a 1/2" piece of PVC that comes through the deck form the shower to an open end. NO VALVE there. I have called everyone I can think of to find why this is backing up and no one knows if or where a valve would be.
I have plunged, used Drain-O, the whole 9 yards and no luck. I understand that there is a possibility that there is a small gray water holding tank inside the starboard pontoon...not sure about that one. I am trying to figure this out before I pull the shower pan up and start looking there.
Does anyone know where a pump out may be or this elusive valve??? Thanks in advance!!
