Re: lower driveshaft upper seal
There are 2 seals in that area. The upper of the 2, (installed from above, with the gears out) seals on the bottom end of the upper drive-shaft, and is part number 26-32511. The lower of the 2, (can be installed with the drive-shaft housing assembled) seals on the top of the lower drive-shaft and is part number 26-965031....
