Re: any suggestions for excess use preventative maint.
Regular use is good for outboards. I've seen far more issues caused by neglect, rather than over use.
Assuming you're running 4 stroke outboards, I agree with adding a high quality fuel filter and water seperator unit like a Racor.
I am NOT a fan of constantly dumping additives, gunk, goo, and assorted snake oil in every tank of fuel. There is an urban legned out there that all these additives somehow "undo" or neutralize ethanol. They do not. Also, no chemical can remove water from fuel. That is a scientific fact. Only a mechanical device can remove water, it cannot be "eaten" by chemicals.
Outboard systems for the last 10 years have been designed and tested to run with ethanol blended fuels. They have NOT been tested to run with high concentrations of additives. Since you're running your outboards every day, your fuel should not be sitting around getting stale. The filter/sep unit will take care of out-of-pump contamination and that's all you should need.
I'm a huge fan of synthetic oil and I have been since the early 1980s when I saw firsthand the difference they could make with aircraft engines. The difference in parts wear between overhauls is dramitic. If you're not running synthetic now, I'd look into it.
Grouse
